Ana içeriğe geç
LG Optimus T Camera and Camera Mount Replacement
Neye ihtiyacın var
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: adım 1, 2 resimden 1. LG Optimus T Camera and Camera Mount Replacement, Camera: adım 1, 2 resimden 2.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: adım 3, 1 resimden 1.
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: adım 4, 2 resimden 1. LG Optimus T Camera and Camera Mount Replacement: adım 4, 2 resimden 2.
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: adım 5, 1 resimden 1.
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: adım 6, 1 resimden 1.
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: adım 7, 2 resimden 1. LG Optimus T Camera and Camera Mount Replacement: adım 7, 2 resimden 2.
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
Sonuç
stacey
219 İtibar
2 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017 üyesi
OSU-WILDER-S17S1G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 20
Her zaman: 145
