Ana içeriğe geç
LG Optimus T Motherboard Replacement
Neye ihtiyacın var
  1. LG Optimus T Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. LG Optimus T Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. LG Optimus T Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a plastic opening tool, remove the phone’s back cover. At the top of the phone, there’s an indentation to put the Spudger into to pop the case off
  2. LG Optimus T Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery. There’s an indentation to the left of the camera lens to pull up on the battery with your finger
  3. LG Optimus T Motherboard Replacement: adım 3, 1 resimden 1.
    • Use a J0 screwdriver to remove the six 4.5mm screws.
  4. LG Optimus T Motherboard Replacement: adım 4, 2 resimden 1. LG Optimus T Motherboard Replacement: adım 4, 2 resimden 2.
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic opening tool fails
    • Remove interior case. Insert the spudger into the indentations at the top, or bottom of the phone to pry off the interior case.
  5. LG Optimus T Motherboard Replacement: adım 5, 1 resimden 1.
    • Pull up on connector tab
  6. LG Optimus T Motherboard Replacement: adım 6, 2 resimden 1. LG Optimus T Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove SD card mount. Insert the plastic opening tool on the right side to pop off
  7. LG Optimus T Motherboard Replacement: adım 7, 2 resimden 1. LG Optimus T Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove metal panel
    • There are four retaining points to insert plastic opening tool and pop off panel
  8. LG Optimus T Motherboard Replacement: adım 8, 1 resimden 1.
    • Use a J0 screwdriver to remove the two 1.8mm screws from charging port. (Charging port and motherboard are connected.)
    • Remove motherboard
Sonuç
Bir başkası bu kılavuzu tamamladı.
stacey
219 İtibar
2 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017 üyesi
OSU-WILDER-S17S1G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 318
