Ana içeriğe geç
LG Optimus T Screen Replacement
Neye ihtiyacın var
  1. LG Optimus T Screen Replacement, Screen: adım 1, 3 resimden 1. LG Optimus T Screen Replacement, Screen: adım 1, 3 resimden 2. LG Optimus T Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using the plastic opening tool to remove the phone’s back cover. At the top of the phone, there’s an indentation to put the tool into to pop the case off.
    FixBot'a Sor
    Yorum Ekle
  2. LG Optimus T Screen Replacement: adım 2, 1 resimden 1.
    • Remove the battery. There’s an indentation to the left of the camera lens.
    FixBot'a Sor
    Yorum Ekle
  3. LG Optimus T Screen Replacement: adım 3, 1 resimden 1.
    • Remove the six (6), J0 Phillip's head, 4.5mm screws.
    • Be sure to retain all screws for reassembly.
    FixBot'a Sor
    Yorum Ekle
  4. LG Optimus T Screen Replacement: adım 4, 2 resimden 1. LG Optimus T Screen Replacement: adım 4, 2 resimden 2.
    • Remove interior case. There are indentations on the top and bottom of the phone. Using a spudger, remove the interior case.
    • You might have difficulty popping the interior case off, and a more durable prying device may be needed.
    FixBot'a Sor
    Yorum Ekle
  5. LG Optimus T Screen Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Pull up connector tab
    • Connector tabs may be difficult to remove, and tweezers may be required to assist removal.
    FixBot'a Sor
    Yorum Ekle
  6. LG Optimus T Screen Replacement: adım 6, 2 resimden 1. LG Optimus T Screen Replacement: adım 6, 2 resimden 2.
    • Remove SD card mount. Use a plastic opening tool to assist removal.
    FixBot'a Sor
    Yorum Ekle
  7. LG Optimus T Screen Replacement: adım 7, 1 resimden 1.
    • Use a J0 screwdriver to remove two 1.8mm screws from the charging port.
    • Charging port and motherboard are connected.
    FixBot'a Sor
    Yorum Ekle
  8. LG Optimus T Screen Replacement: adım 8, 2 resimden 1. LG Optimus T Screen Replacement: adım 8, 2 resimden 2.
    • Remove connector tab. Then remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. LG Optimus T Screen Replacement: adım 9, 2 resimden 1. LG Optimus T Screen Replacement: adım 9, 2 resimden 2.
    • Using a spudger, gently pry off the metal panel on the back of the screen attached by 4 retaining points.
    • Remove the screen from the front of your device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Edward Farris
112 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017 üyesi
OSU-WILDER-S17S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 398
