Ana içeriğe geç
LG Optimus V Antenna Replacement
Neye ihtiyacın var
  1. LG Optimus V Antenna Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Antenna Replacement: adım 2, 1 resimden 1.
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Antenna Replacement: adım 3, 3 resimden 1. LG Optimus V Antenna Replacement: adım 3, 3 resimden 2. LG Optimus V Antenna Replacement: adım 3, 3 resimden 3.
    • Gently remove the battery with your spudger.
  4. LG Optimus V Antenna Replacement, Camera: adım 4, 2 resimden 1. LG Optimus V Antenna Replacement, Camera: adım 4, 2 resimden 2.
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Antenna Replacement: adım 5, 3 resimden 1. LG Optimus V Antenna Replacement: adım 5, 3 resimden 2. LG Optimus V Antenna Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Antenna Replacement: adım 6, 2 resimden 1. LG Optimus V Antenna Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Antenna Replacement, Antenna: adım 7, 2 resimden 1. LG Optimus V Antenna Replacement, Antenna: adım 7, 2 resimden 2.
    • Use a soldering iron to desolder the connections attaching the the antenna to the motherboard.
  8. LG Optimus V Antenna Replacement: adım 8, 1 resimden 1.
    • Solder off the antenna, and solder on the new one. The antenna is now replaced.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joseph Pasquantonio
683 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Shastany Fall 2013 UMass Dartmouth, Team 1-2, Shastany Fall 2013 üyesi
UMASSD-SHASTANY-F13S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 2,195
