Ana içeriğe geç
LG Phoenix 2 Camera Replacement
Neye ihtiyacın var
    1. LG Phoenix 2 Camera Replacement, Battery: adım 1, 3 resimden 1. LG Phoenix 2 Camera Replacement, Battery: adım 1, 3 resimden 2. LG Phoenix 2 Camera Replacement, Battery: adım 1, 3 resimden 3.
      • Place a fingernail in the notch at the bottom edge of the phone.
      • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
      FixBot'a Sor
      Yorum Ekle
    2. LG Phoenix 2 Camera Replacement: adım 2, 3 resimden 1. LG Phoenix 2 Camera Replacement: adım 2, 3 resimden 2. LG Phoenix 2 Camera Replacement: adım 2, 3 resimden 3.
      • Place a fingernail in the notch at the bottom edge of the battery.
      • Pull the battery out.
      FixBot'a Sor
      Yorum Ekle
    1. LG Phoenix 2 Camera Replacement, Rear Camera: adım 3, 2 resimden 1. LG Phoenix 2 Camera Replacement, Rear Camera: adım 3, 2 resimden 2.
      • Locate the SIM card in the top right corner on the back of the phone.
      • Remove the SIM card by pushing it with your thumb from left to right.
      FixBot'a Sor
      Yorum Ekle
    2. LG Phoenix 2 Camera Replacement: adım 4, 3 resimden 1. LG Phoenix 2 Camera Replacement: adım 4, 3 resimden 2. LG Phoenix 2 Camera Replacement: adım 4, 3 resimden 3.
      • Remove all 9 screws on the back by using a Phillips head #00 screwdriver.
      • To remove the screws rotate them counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    3. LG Phoenix 2 Camera Replacement: adım 5, 3 resimden 1. LG Phoenix 2 Camera Replacement: adım 5, 3 resimden 2. LG Phoenix 2 Camera Replacement: adım 5, 3 resimden 3.
      • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
      • Pry the bottom shield to separate it from the phone.
      • Once it is loose you should be able to remove it with your hand.
      FixBot'a Sor
      Yorum Ekle
    4. LG Phoenix 2 Camera Replacement: adım 6, 3 resimden 1. LG Phoenix 2 Camera Replacement: adım 6, 3 resimden 2. LG Phoenix 2 Camera Replacement: adım 6, 3 resimden 3.
      • Insert the flat end of the Spudger between the screen and the chromed frame.
      • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
      FixBot'a Sor
      Yorum Ekle
    5. LG Phoenix 2 Camera Replacement: adım 7, 3 resimden 1. LG Phoenix 2 Camera Replacement: adım 7, 3 resimden 2. LG Phoenix 2 Camera Replacement: adım 7, 3 resimden 3.
      • Insert the flat end of the Spudger or the plastic opening tool underneath the camera connector.
      • Gently lever the camera connector free.
      • Once disconnected, take the camera out.
      FixBot'a Sor
      Yorum Ekle
    6. LG Phoenix 2 Camera Replacement: adım 8, 3 resimden 1. LG Phoenix 2 Camera Replacement: adım 8, 3 resimden 2. LG Phoenix 2 Camera Replacement: adım 8, 3 resimden 3.
      • The front camera can be removed in a similar way as the rear camera. See previous step.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Esteban Ruibal
705 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Eyestone Spring 2018 USF Tampa, Team S2-G2, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G2
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 1,026
