Ana içeriğe geç
LG Phoenix 2 Screen Replacement
Neye ihtiyacın var
    1. LG Phoenix 2 Screen Replacement, Battery: adım 1, 3 resimden 1. LG Phoenix 2 Screen Replacement, Battery: adım 1, 3 resimden 2. LG Phoenix 2 Screen Replacement, Battery: adım 1, 3 resimden 3.
      • Place a fingernail in the notch at the bottom edge of the phone.
      • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
      FixBot'a Sor
      Yorum Ekle
    2. LG Phoenix 2 Screen Replacement: adım 2, 3 resimden 1. LG Phoenix 2 Screen Replacement: adım 2, 3 resimden 2. LG Phoenix 2 Screen Replacement: adım 2, 3 resimden 3.
      • Place a fingernail in the notch at the bottom edge of the battery.
      • Pull the battery out.
      FixBot'a Sor
      Yorum Ekle
    1. LG Phoenix 2 Screen Replacement, Rear Camera: adım 3, 2 resimden 1. LG Phoenix 2 Screen Replacement, Rear Camera: adım 3, 2 resimden 2.
      • Locate the SIM card in the top right corner on the back of the phone.
      • Remove the SIM card by pushing it with your thumb from left to right.
      FixBot'a Sor
      Yorum Ekle
    2. LG Phoenix 2 Screen Replacement: adım 4, 3 resimden 1. LG Phoenix 2 Screen Replacement: adım 4, 3 resimden 2. LG Phoenix 2 Screen Replacement: adım 4, 3 resimden 3.
      • Remove all 9 screws on the back by using a Phillips head #00 screwdriver.
      • To remove the screws rotate them counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    3. LG Phoenix 2 Screen Replacement: adım 5, 3 resimden 1. LG Phoenix 2 Screen Replacement: adım 5, 3 resimden 2. LG Phoenix 2 Screen Replacement: adım 5, 3 resimden 3.
      • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
      • Pry the bottom shield to separate it from the phone.
      • Once it is loose you should be able to remove it with your hand.
      FixBot'a Sor
      Yorum Ekle
    4. LG Phoenix 2 Screen Replacement: adım 6, 3 resimden 1. LG Phoenix 2 Screen Replacement: adım 6, 3 resimden 2. LG Phoenix 2 Screen Replacement: adım 6, 3 resimden 3.
      • Insert the flat end of the Spudger between the screen and the chromed frame.
      • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
      FixBot'a Sor
      Yorum Ekle
    5. LG Phoenix 2 Screen Replacement: adım 7, 3 resimden 1. LG Phoenix 2 Screen Replacement: adım 7, 3 resimden 2. LG Phoenix 2 Screen Replacement: adım 7, 3 resimden 3.
      • Insert the flat end of the Spudger or the plastic opening tool underneath the camera connector.
      • Gently lever the camera connector free.
      • Once disconnected, take the camera out.
      FixBot'a Sor
      Yorum Ekle
    6. LG Phoenix 2 Screen Replacement: adım 8, 3 resimden 1. LG Phoenix 2 Screen Replacement: adım 8, 3 resimden 2. LG Phoenix 2 Screen Replacement: adım 8, 3 resimden 3.
      • The front camera can be removed in a similar way as the rear camera. See previous step.
      FixBot'a Sor
      Yorum Ekle
    1. LG Phoenix 2 Screen Replacement, Screen: adım 9, 3 resimden 1. LG Phoenix 2 Screen Replacement, Screen: adım 9, 3 resimden 2. LG Phoenix 2 Screen Replacement, Screen: adım 9, 3 resimden 3.
      • Remove the speaker using the Spudger.
      FixBot'a Sor
      Yorum Ekle
    2. LG Phoenix 2 Screen Replacement: adım 10, 3 resimden 1. LG Phoenix 2 Screen Replacement: adım 10, 3 resimden 2. LG Phoenix 2 Screen Replacement: adım 10, 3 resimden 3.
      • Remove the screen connector using the Spudger.
      FixBot'a Sor
      Yorum Ekle
    3. LG Phoenix 2 Screen Replacement: adım 11, 2 resimden 1. LG Phoenix 2 Screen Replacement: adım 11, 2 resimden 2.
      • Using a Spudger, separate the motherboard from the back frame.
      FixBot'a Sor
      Yorum Ekle
    4. LG Phoenix 2 Screen Replacement: adım 12, 2 resimden 1. LG Phoenix 2 Screen Replacement: adım 12, 2 resimden 2.
      • Heat the screen up using a heat gun (or the IOpener) to loosen up the screen. The heat gun needs to be moved around the edges of the phone in order to equally heat the edges.
      FixBot'a Sor
      Yorum Ekle
    5. LG Phoenix 2 Screen Replacement: adım 13, 3 resimden 1. LG Phoenix 2 Screen Replacement: adım 13, 3 resimden 2. LG Phoenix 2 Screen Replacement: adım 13, 3 resimden 3.
      • Pick the Jimmy and slide it's blade around the edge of the screen.
      • Separate the screen from the frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Esteban Ruibal
705 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Eyestone Spring 2018 USF Tampa, Team S2-G2, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G2
4 Üyeler
60 adet Kılavuz yazıldı
2Kılavuz Yorumları
Works for the Phoenix 3 as well but I wouldn’t try taking out the rear facing camera. You shouldn’t have to either way.
dtcarani - Yanıt Paylaş
“Works for the Phoenix 3 as well but I wouldn’t try taking out the rear facing camera. You shouldn’t have to either way” -dtcarani
Thank you dtcarani it absolutely does work for the Phoenix 3.
And, I did not need to remove the rear facing camera.
John Faires - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 68
Her zaman: 5,573
