Ana içeriğe geç
LG Phoenix 2 Speaker Replacement
Neye ihtiyacın var
  1. LG Phoenix 2 Speaker Replacement, Battery: adım 1, 3 resimden 1. LG Phoenix 2 Speaker Replacement, Battery: adım 1, 3 resimden 2. LG Phoenix 2 Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Speaker Replacement: adım 2, 3 resimden 1. LG Phoenix 2 Speaker Replacement: adım 2, 3 resimden 2. LG Phoenix 2 Speaker Replacement: adım 2, 3 resimden 3.
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Speaker Replacement, Speaker: adım 3, 2 resimden 1. LG Phoenix 2 Speaker Replacement, Speaker: adım 3, 2 resimden 2.
    • Locate the SIM card in the top right corner on the back of the phone.
    • Remove the SIM card by pushing it with your thumb from left to right.
  4. LG Phoenix 2 Speaker Replacement: adım 4, 3 resimden 1. LG Phoenix 2 Speaker Replacement: adım 4, 3 resimden 2. LG Phoenix 2 Speaker Replacement: adım 4, 3 resimden 3.
    • Remove all 9 screws on the back by using a Phillips head #J00 screwdriver.
    • To remove the screws rotate them counterclockwise.
  5. LG Phoenix 2 Speaker Replacement: adım 5, 3 resimden 1. LG Phoenix 2 Speaker Replacement: adım 5, 3 resimden 2. LG Phoenix 2 Speaker Replacement: adım 5, 3 resimden 3.
    • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
    • Pry the bottom shield to separate it from the phone.
    • Once it is loose you should be able to remove it with your hand.
  6. LG Phoenix 2 Speaker Replacement: adım 6, 3 resimden 1. LG Phoenix 2 Speaker Replacement: adım 6, 3 resimden 2. LG Phoenix 2 Speaker Replacement: adım 6, 3 resimden 3.
    • Insert the flat end of the Spudger between the screen and the chromed frame.
    • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
  7. LG Phoenix 2 Speaker Replacement: adım 7, 3 resimden 1. LG Phoenix 2 Speaker Replacement: adım 7, 3 resimden 2. LG Phoenix 2 Speaker Replacement: adım 7, 3 resimden 3.
    • Remove the speaker by using the Spudger.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Esteban Ruibal
702 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Eyestone Spring 2018 USF Tampa, Team S2-G2, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 474
