Ana içeriğe geç
LG Power Back Camera Replacement
Neye ihtiyacın var
  1. LG Power Back Camera Replacement, Battery: adım 1, 2 resimden 1. LG Power Back Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
    • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
  2. LG Power Back Camera Replacement: adım 2, 2 resimden 1. LG Power Back Camera Replacement: adım 2, 2 resimden 2.
    • Carefully pop the back panel off and place it to the side.
  3. LG Power Back Camera Replacement: adım 3, 2 resimden 1. LG Power Back Camera Replacement: adım 3, 2 resimden 2.
    • Use the thumb tab to remove the battery.
  4. LG Power Back Camera Replacement, Back Camera: adım 4, 1 resimden 1.
    • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
  5. LG Power Back Camera Replacement: adım 5, 2 resimden 1. LG Power Back Camera Replacement: adım 5, 2 resimden 2.
    • Slide a plastic opening tool between the mid-panel and front panel to remove the middle panel.
    • Place the mid panel to the side.
  6. LG Power Back Camera Replacement: adım 6, 2 resimden 1. LG Power Back Camera Replacement: adım 6, 2 resimden 2.
    • Detach the back camera from the back of the mid panel using a plastic opening tool, and remove it.
    • The camera will be completely free at this point.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mohammed Samin
136 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Lacy Spring 2016 USF Tampa, Team 4-6, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 488
