Ana içeriğe geç
LG Power Screen Replacement
Neye ihtiyacın var
  1. LG Power Screen Replacement, Battery: adım 1, 2 resimden 1. LG Power Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
    • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
    FixBot'a Sor
    Yorum Ekle
  2. LG Power Screen Replacement: adım 2, 2 resimden 1. LG Power Screen Replacement: adım 2, 2 resimden 2.
    • Carefully pop the back panel off and place it to the side.
    FixBot'a Sor
    Yorum Ekle
  3. LG Power Screen Replacement: adım 3, 2 resimden 1. LG Power Screen Replacement: adım 3, 2 resimden 2.
    • Use the thumb tab to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  4. LG Power Screen Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
    FixBot'a Sor
    Yorum Ekle
  5. LG Power Screen Replacement: adım 5, 2 resimden 1. LG Power Screen Replacement: adım 5, 2 resimden 2.
    • Slide a plastic opening tool between the mid and front panel to remove the middle panel.
    • Place the mid panel to the side.
    FixBot'a Sor
    Yorum Ekle
  6. LG Power Screen Replacement: adım 6, 3 resimden 1. LG Power Screen Replacement: adım 6, 3 resimden 2. LG Power Screen Replacement: adım 6, 3 resimden 3.
    • Detach the motherboard and touchscreen from each other by using a plastic opening tool.
    • The motherboard will then be free from the phone.
    FixBot'a Sor
    Yorum Ekle
  7. LG Power Screen Replacement, Screen: adım 7, 3 resimden 1. LG Power Screen Replacement, Screen: adım 7, 3 resimden 2. LG Power Screen Replacement, Screen: adım 7, 3 resimden 3.
    • After removing the motherboard, slide a thin plastic opening tool between the screen and the frame.
    • This step may take awhile, because of the glue keeping the frame and screen together.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Nadia Wilson
925 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Lacy Spring 2016 USF Tampa, Team 4-6, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G6
4 Üyeler
15 adet Kılavuz yazıldı
9Kılavuz Yorumları
do i need a replacement screen?
jj - Yanıt Paylaş
My screen is shattered otherwise the phone works fine..touch works and screen under glass is good. I want to replace the screen myself but my question is are the screen and digitizer fused (one piece) or can I just replace the glass screen? For an LG power x
Nikki - Yanıt Paylaş
Did you ever figure out if there the same or separate. I'm needing to do the same.
sarahelizabeth0526 - Yanıt Paylaş
Where do I buy the glass panel?
Liam McBride - Yanıt Paylaş
i got the glass screen at amazonbot most digitisers have a ribbon wire to connecttheres doesnt..not sure if its just held on with 2 face tape??
Peter Maggiop - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 34
Her zaman: 26,653
