Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. LG Prime GS390 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. LG Prime GS390 Teardown, LG Prime GS390 Teardown: adım 1, 1 resimden 1.
    • Remove the plastic shell that covers the back of the phone by applying pressure with two fingers in a downward sliding motion.
  2. LG Prime GS390 Teardown: adım 2, 1 resimden 1.
    • Remove the four black screws securing the corners of the phone using a small Phillips screwdriver.
  3. LG Prime GS390 Teardown: adım 3, 1 resimden 1.
    • At this point, you should be able to easily pull off the small console at the base of the phone, below the screen, that contains the circular silver home button.
  4. LG Prime GS390 Teardown: adım 4, 1 resimden 1.
    • Remove the black, rectangular battery labeled LG Li-Ion Battery (3.7V) by lightly applying pressure to the center. The battery should pop out.
  5. LG Prime GS390 Teardown: adım 5, 1 resimden 1.
    • Next, extract the orange and white plastic SIM card from the back of the phone by using a finger to slide it out from underneath the thin metal bar that holds it in place.
  6. LG Prime GS390 Teardown: adım 6, 1 resimden 1.
    • Detach the printed wiring circuit board by gently pulling it away from the back cover. Because the screws have already been removed, the circuit board should come apart easily; it is now attached to the back cover by two thin red and black wires. Two blue and pink colored wires connect the circuit board to a small circular capacitor.
  7. LG Prime GS390 Teardown: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of thin tweezers to carefully pry the rectangular display plate from the front casing. Slide one of the sharp ends of the tweezers between the display plate and the plastic case and lightly apply pressure until the plate pops out. The display plate will still be attached to the circuit board by a single strip of orange wire tape.
  8. LG Prime GS390 Teardown: adım 8, 1 resimden 1.
    • Separate the display plate from the circuit board by pulling on the orange wire tape that connects the black rectangle at the edge of the wire tape to the circuit board.
Jackie
138 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 1,456
