Ana içeriğe geç
LG Realm Motherboard Replacement
Neye ihtiyacın var
  1. LG Realm Motherboard Replacement, Battery: adım 1, 2 resimden 1. LG Realm Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
    FixBot'a Sor
    Yorum Ekle
  2. LG Realm Motherboard Replacement: adım 2, 1 resimden 1.
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
    FixBot'a Sor
    Yorum Ekle
  3. LG Realm Motherboard Replacement, Plastic Midframe: adım 3, 2 resimden 1. LG Realm Motherboard Replacement, Plastic Midframe: adım 3, 2 resimden 2.
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
    FixBot'a Sor
    Yorum Ekle
  4. LG Realm Motherboard Replacement: adım 4, 1 resimden 1.
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. LG Realm Motherboard Replacement, Rear Facing Camera: adım 5, 1 resimden 1.
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
    FixBot'a Sor
    Yorum Ekle
  6. LG Realm Motherboard Replacement: adım 6, 1 resimden 1.
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
    FixBot'a Sor
    Yorum Ekle
  7. LG Realm Motherboard Replacement, Front Facing Camera: adım 7, 1 resimden 1.
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
    FixBot'a Sor
    Yorum Ekle
  8. LG Realm Motherboard Replacement: adım 8, 1 resimden 1.
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
    FixBot'a Sor
    Yorum Ekle
  9. LG Realm Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Locate where the motherboard connects to the orange sisterboard. Using the plastic opening tool, disconnect the connection between the phone and the orange ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  10. LG Realm Motherboard Replacement: adım 10, 2 resimden 1. LG Realm Motherboard Replacement: adım 10, 2 resimden 2.
    • Locate the ribbon cables in the top right corner of the motherboard. Using the plastic opening tool, remove the ribbon cables from phone.
    FixBot'a Sor
    Yorum Ekle
  11. LG Realm Motherboard Replacement: adım 11, 1 resimden 1.
    • Using the plastic opening tool, disconnect the ribbon cable that connects the antenna to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  12. LG Realm Motherboard Replacement: adım 12, 1 resimden 1.
    • Using the plastic opening tool, carefully remove the motherboard from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ryan St Martin
785 İtibar
4 adet Kılavuz yazıldı
Ekip
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016 üyesi
MARS-LAFLEN-S16S1G5
2 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 1,557
