Ana içeriğe geç
LG Realm Plastic Midframe Replacement
Neye ihtiyacın var
  1. LG Realm Plastic Midframe Replacement, Battery: adım 1, 2 resimden 1. LG Realm Plastic Midframe Replacement, Battery: adım 1, 2 resimden 2.
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Plastic Midframe Replacement: adım 2, 1 resimden 1.
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Plastic Midframe Replacement, Plastic Midframe: adım 3, 2 resimden 1. LG Realm Plastic Midframe Replacement, Plastic Midframe: adım 3, 2 resimden 2.
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Plastic Midframe Replacement: adım 4, 1 resimden 1.
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ryan St Martin
770 İtibar
4 adet Kılavuz yazıldı
Ekip
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016 üyesi
MARS-LAFLEN-S16S1G5
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 314
