Giriş
Before continuing, make sure the device is powered down.
Neye ihtiyacın var
To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
Use nail to loosen case on all four sides. Once loose, remove back case.
Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
5 farklı kişi bu kılavuzu tamamladı.
