Ana içeriğe geç
LG Realm Rear Facing Camera Replacement
Neye ihtiyacın var
  1. LG Realm Rear Facing Camera Replacement, Battery: adım 1, 2 resimden 1. LG Realm Rear Facing Camera Replacement, Battery: adım 1, 2 resimden 2.
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Rear Facing Camera Replacement: adım 2, 1 resimden 1.
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Rear Facing Camera Replacement, Plastic Midframe: adım 3, 2 resimden 1. LG Realm Rear Facing Camera Replacement, Plastic Midframe: adım 3, 2 resimden 2.
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Rear Facing Camera Replacement: adım 4, 1 resimden 1.
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Rear Facing Camera Replacement, Rear Facing Camera: adım 5, 1 resimden 1.
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
  6. LG Realm Rear Facing Camera Replacement: adım 6, 1 resimden 1.
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Emily Palmer
287 İtibar
1 Kılavuz yazıldı
Ekip
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016 üyesi
MARS-LAFLEN-S16S1G5
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 267
