Ana içeriğe geç
LG Rebel 4 LTE Disassembly
Neye ihtiyacın var
  1. LG Rebel 4 LTE Disassembly, Remove the Cover: adım 1, 2 resimden 1. LG Rebel 4 LTE Disassembly, Remove the Cover: adım 1, 2 resimden 2.
    • Locate the indent on the back left side of the phone.
    • Insert the opening tool into the indent and pry until it pops.
    • Remove the backing.
  2. LG Rebel 4 LTE Disassembly, Remove Internal Components: adım 2, 3 resimden 1. LG Rebel 4 LTE Disassembly, Remove Internal Components: adım 2, 3 resimden 2. LG Rebel 4 LTE Disassembly, Remove Internal Components: adım 2, 3 resimden 3.
    • Use the spudger to pry the battery out.
    • If installed, pop out the SD/TF card by gently pressing in and releasing the SD card. Not pictured, Located above the Sims card (See Below).
    • Use your fingers to remove the sim card.
  3. LG Rebel 4 LTE Disassembly, Remove Screws: adım 3, 3 resimden 1. LG Rebel 4 LTE Disassembly, Remove Screws: adım 3, 3 resimden 2. LG Rebel 4 LTE Disassembly, Remove Screws: adım 3, 3 resimden 3.
    • Using the #000 Phillips screwdriver, remove all the screws (as seen in the photo).
    • There should be 12 screws in total.
    • Don't lose the screws!
  4. LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: adım 4, 2 resimden 1. LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: adım 4, 2 resimden 2.
    • Use the spudger to carefully pry the cover around the charging port.
  5. LG Rebel 4 LTE Disassembly, Remove the Screen: adım 5, 3 resimden 1. LG Rebel 4 LTE Disassembly, Remove the Screen: adım 5, 3 resimden 2. LG Rebel 4 LTE Disassembly, Remove the Screen: adım 5, 3 resimden 3.
    • Rotate the phone (view picture) to reveal the top corner of the phone.
    • Using a opening pick, pry in between the glass screen and the framing.
  6. LG Rebel 4 LTE Disassembly, Remove the Motherboard: adım 6, 3 resimden 1. LG Rebel 4 LTE Disassembly, Remove the Motherboard: adım 6, 3 resimden 2. LG Rebel 4 LTE Disassembly, Remove the Motherboard: adım 6, 3 resimden 3.
    • Pry from the top and bottom of the screen with the (refer to photo) opening pick to release the tabs holding the motherboard to the phone.
    • Do not let the main camera fall out while removing the mother board.
  7. LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: adım 7, 3 resimden 1. LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: adım 7, 3 resimden 2. LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: adım 7, 3 resimden 3.
    • On the bottom right of the phone, locate a cable that holds the motherboard to the phone.
    • Disconnect the cable by gently pulling up on the component with your fingers.
    • Do not use a prying tool or screwdriver to disconnect the cable.
  8. LG Rebel 4 LTE Disassembly, Remove the Camera: adım 8, 3 resimden 1. LG Rebel 4 LTE Disassembly, Remove the Camera: adım 8, 3 resimden 2. LG Rebel 4 LTE Disassembly, Remove the Camera: adım 8, 3 resimden 3.
    • Separate the camera from the magnet by gently pulling up.
  9. LG Rebel 4 LTE Disassembly, Disassembly Complete: adım 9, 1 resimden 1.
    • Congratulations. You've successfully disassembled your device.
    • To reassemble the device, follow these steps in reverse order. (Begin with step 8, continuining until you end on step 1.
    • When reassembling, make sure that each component snaps tightly to the phone before moving to the next step.
Sonuç
JCJR
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 17
Her zaman: 172
