Giriş
A step-by-step guide on how to successfully disassemble a LG Rebel 4 phone.
Neye ihtiyacın var
Locate the indent on the back left side of the phone.
Insert the opening tool into the indent and pry until it pops.
Remove the backing.
Use the spudger to pry the battery out.
If installed, pop out the SD/TF card by gently pressing in and releasing the SD card. Not pictured, Located above the Sims card (See Below).
Use your fingers to remove the sim card.
Using the #000 Phillips screwdriver, remove all the screws (as seen in the photo).
Use the spudger to carefully pry the cover around the charging port.
Rotate the phone (view picture) to reveal the top corner of the phone.
Using a opening pick, pry in between the glass screen and the framing.
Pry from the top and bottom of the screen with the (refer to photo) opening pick to release the tabs holding the motherboard to the phone.
On the bottom right of the phone, locate a cable that holds the motherboard to the phone.
Disconnect the cable by gently pulling up on the component with your fingers.
Congratulations. You've successfully disassembled your device.
To reassemble the device, follow these steps in reverse order. (Begin with step 8, continuining until you end on step 1.
