Ana içeriğe geç
LG Rebel Front Camera Replacement
Neye ihtiyacın var
  1. LG Rebel Front Camera Replacement, Front Camera: adım 1, 3 resimden 1. LG Rebel Front Camera Replacement, Front Camera: adım 1, 3 resimden 2. LG Rebel Front Camera Replacement, Front Camera: adım 1, 3 resimden 3.
    • Turn phone over to its front side.
    • Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen.
  2. LG Rebel Front Camera Replacement: adım 2, 3 resimden 1. LG Rebel Front Camera Replacement: adım 2, 3 resimden 2. LG Rebel Front Camera Replacement: adım 2, 3 resimden 3.
    • Once you have loosened the grip around the edges, pop off the screen using a suction cup.
    • Once the front screen is removed, place the phone on its side and find the groove located on the side.
    • Use the plastic opening tool to pop open the black plastic covering.
    • Remove black plastic cover.
  3. LG Rebel Front Camera Replacement: adım 3, 3 resimden 1. LG Rebel Front Camera Replacement: adım 3, 3 resimden 2. LG Rebel Front Camera Replacement: adım 3, 3 resimden 3.
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  4. LG Rebel Front Camera Replacement: adım 4, 2 resimden 1. LG Rebel Front Camera Replacement: adım 4, 2 resimden 2.
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  5. LG Rebel Front Camera Replacement: adım 5, 3 resimden 1. LG Rebel Front Camera Replacement: adım 5, 3 resimden 2. LG Rebel Front Camera Replacement: adım 5, 3 resimden 3.
    • Remove the motherboard with a spudger.
    • Slowly begin to lift motherboard with your hand carefully.
    • Once the motherboard is completely off, set the phone to the side and focus on the small black box with a square tail (which is the front camera).
  6. LG Rebel Front Camera Replacement: adım 6, 2 resimden 1. LG Rebel Front Camera Replacement: adım 6, 2 resimden 2.
    • Remove the front camera by its tail with a spudger.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lesley Sigaran
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 355
