Ana içeriğe geç
LG Rebel Motherboard Replacement
Neye ihtiyacın var
  1. LG Rebel Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. LG Rebel Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Insert the plastic opening tool into the small groove on the side of the phone.
    • Remove the back cover with the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  2. LG Rebel Motherboard Replacement: adım 2, 3 resimden 1. LG Rebel Motherboard Replacement: adım 2, 3 resimden 2. LG Rebel Motherboard Replacement: adım 2, 3 resimden 3.
    • Insert the metal spudger into the small groove on the back of the phone.
    • Lift and remove the black plastic covering with the metal spudger.
    FixBot'a Sor
    Yorum Ekle
  3. LG Rebel Motherboard Replacement: adım 3, 2 resimden 1. LG Rebel Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the metal spudger to lift the remaining black plastic cover pieces.
    FixBot'a Sor
    Yorum Ekle
  4. LG Rebel Motherboard Replacement: adım 4, 3 resimden 1. LG Rebel Motherboard Replacement: adım 4, 3 resimden 2. LG Rebel Motherboard Replacement: adım 4, 3 resimden 3.
    • Use the metal spudger to lift and disconnect the two connective pieces on the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. LG Rebel Motherboard Replacement: adım 5, 3 resimden 1. LG Rebel Motherboard Replacement: adım 5, 3 resimden 2. LG Rebel Motherboard Replacement: adım 5, 3 resimden 3.
    • Flip the phone, so that the screen is facing upwards.
    • Slide the metal spudger along the perimeter of the phone in order to break the entire seal.
    • Use the suction cup to lift and remove the screen.
    FixBot'a Sor
    Yorum Ekle
  6. LG Rebel Motherboard Replacement: adım 6, 2 resimden 1. LG Rebel Motherboard Replacement: adım 6, 2 resimden 2.
    • Use the metal spudger to slide the black bumper out from the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  7. LG Rebel Motherboard Replacement: adım 7, 3 resimden 1. LG Rebel Motherboard Replacement: adım 7, 3 resimden 2. LG Rebel Motherboard Replacement: adım 7, 3 resimden 3.
    • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
    • Slowly slide the motherboard out of the body of the phone.
    • Remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Justin Franklin
201 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
First time tearing apart a phone. His instructions are spot on. Pretty easy phone though.
Bruce Simmons - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 32
Her zaman: 1,907
