Ana içeriğe geç
LG Risio Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. LG Risio Rear-Facing Camera Replacement, Back Panel: adım 1, 2 resimden 1. LG Risio Rear-Facing Camera Replacement, Back Panel: adım 1, 2 resimden 2.
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Rear-Facing Camera Replacement, Battery: adım 2, 1 resimden 1.
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Rear-Facing Camera Replacement, Midframe: adım 3, 1 resimden 1.
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Rear-Facing Camera Replacement: adım 4, 2 resimden 1. LG Risio Rear-Facing Camera Replacement: adım 4, 2 resimden 2.
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Rear-Facing Camera Replacement: adım 5, 3 resimden 1. LG Risio Rear-Facing Camera Replacement: adım 5, 3 resimden 2. LG Risio Rear-Facing Camera Replacement: adım 5, 3 resimden 3.
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Rear-Facing Camera Replacement: adım 6, 1 resimden 1.
    • Using your hand, pick up the midframe to separate it from the phone.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 115
