Ana içeriğe geç
LG Spectrum Audio Port Replacement
Neye ihtiyacın var
    1. LG Spectrum Audio Port Replacement, Battery: adım 1, 2 resimden 1. LG Spectrum Audio Port Replacement, Battery: adım 1, 2 resimden 2.
      • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG Spectrum Audio Port Replacement: adım 2, 1 resimden 1.
      • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG Spectrum Audio Port Replacement, Audio Port: adım 3, 2 resimden 1. LG Spectrum Audio Port Replacement, Audio Port: adım 3, 2 resimden 2.
      • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
      • Use the magnet board to keep the screws in one place.
      FixBot'a Sor
      Yorum Ekle
    2. LG Spectrum Audio Port Replacement: adım 4, 1 resimden 1.
      • Use the plastic opening tool to firmly unhinge the plastic backing around the perimeter of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. LG Spectrum Audio Port Replacement: adım 5, 2 resimden 1. LG Spectrum Audio Port Replacement: adım 5, 2 resimden 2.
      • Using the plastic opening tool, gently pry up the plastic film connecting the audio port to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. LG Spectrum Audio Port Replacement: adım 6, 1 resimden 1.
      • Remove the audio port from the motherboard either with your hand or the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Aiman Sallam
506 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Sullivan Spring 2016 USF Tampa, Team 1-4, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G4
3 Üyeler
35 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 468
