Ana içeriğe geç
LG Spectrum Camera Replacement
Neye ihtiyacın var
  1. LG Spectrum Camera Replacement, Battery: adım 1, 2 resimden 1. LG Spectrum Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. LG Spectrum Camera Replacement: adım 2, 1 resimden 1.
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. LG Spectrum Camera Replacement, Camera: adım 3, 2 resimden 1. LG Spectrum Camera Replacement, Camera: adım 3, 2 resimden 2.
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnet board to keep the screws in one place.
  4. LG Spectrum Camera Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
  5. LG Spectrum Camera Replacement: adım 5, 2 resimden 1. LG Spectrum Camera Replacement: adım 5, 2 resimden 2.
    • Remove the camera by gently lifting the film that is attached to it from motherboard with the plastic opening tool.
  6. LG Spectrum Camera Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool, or your hand, to pull up on the camera and remove it from the motherboard.
Sonuç
Aiman Sallam
506 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Sullivan Spring 2016 USF Tampa, Team 1-4, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 314
