Ana içeriğe geç
LG Spectrum Motherboard Replacement
Neye ihtiyacın var
  1. LG Spectrum Motherboard Replacement, Battery: adım 1, 2 resimden 1. LG Spectrum Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. LG Spectrum Motherboard Replacement: adım 2, 1 resimden 1.
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. LG Spectrum Motherboard Replacement, Sim/SD Port: adım 3, 2 resimden 1. LG Spectrum Motherboard Replacement, Sim/SD Port: adım 3, 2 resimden 2.
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
  4. LG Spectrum Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
  5. LG Spectrum Motherboard Replacement: adım 5, 1 resimden 1.
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
  6. LG Spectrum Motherboard Replacement: adım 6, 1 resimden 1.
    • Hook the plastic opening tool underneath the plate and gently lift it up.
  7. LG Spectrum Motherboard Replacement: adım 7, 1 resimden 1.
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
  8. LG Spectrum Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. LG Spectrum Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Use the plastic opening tool to lift up the connector that holds the camera to the board.
  9. LG Spectrum Motherboard Replacement: adım 9, 1 resimden 1.
    • Pull the camera gently out of its housing in the motherboard with your fingers.
  10. LG Spectrum Motherboard Replacement: adım 10, 2 resimden 1. LG Spectrum Motherboard Replacement: adım 10, 2 resimden 2.
    • Using the plastic opening tool, gently pry up the audio port connector.
  11. LG Spectrum Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the audio port from the motherboard with either your hand or the plastic opening tool.
  12. LG Spectrum Motherboard Replacement: adım 12, 2 resimden 1. LG Spectrum Motherboard Replacement: adım 12, 2 resimden 2.
    • Detach the two cable connector wires from the motherboard with the plastic opening tool.
    • Detach the remaining five connectors from the phone with the plastic opening tool.
  13. LG Spectrum Motherboard Replacement: adım 13, 2 resimden 1. LG Spectrum Motherboard Replacement: adım 13, 2 resimden 2.
    • Hook the plastic opening tool underneath the motherboard and firmly lift it out of the phone casing.
Sonuç
Aiman Sallam
506 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Sullivan Spring 2016 USF Tampa, Team 1-4, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 607
