Ana içeriğe geç
LG Spectrum Sim/SD Port Replacement
Neye ihtiyacın var
    1. LG Spectrum Sim/SD Port Replacement, Battery: adım 1, 2 resimden 1. LG Spectrum Sim/SD Port Replacement, Battery: adım 1, 2 resimden 2.
      • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG Spectrum Sim/SD Port Replacement: adım 2, 1 resimden 1.
      • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG Spectrum Sim/SD Port Replacement, Sim/SD Port: adım 3, 2 resimden 1. LG Spectrum Sim/SD Port Replacement, Sim/SD Port: adım 3, 2 resimden 2.
      • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
      • Use the magnetic mat to keep the screws in one place.
      FixBot'a Sor
      Yorum Ekle
    2. LG Spectrum Sim/SD Port Replacement: adım 4, 1 resimden 1.
      • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. LG Spectrum Sim/SD Port Replacement: adım 5, 1 resimden 1.
      • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. LG Spectrum Sim/SD Port Replacement: adım 6, 1 resimden 1.
      • Hook the plastic opening tool underneath the plate and gently lift it up.
      FixBot'a Sor
      Yorum Ekle
    5. LG Spectrum Sim/SD Port Replacement: adım 7, 1 resimden 1.
      • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Aiman Sallam
506 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Sullivan Spring 2016 USF Tampa, Team 1-4, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G4
3 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 445
