Ana içeriğe geç
LG Stylo 2 Display Replacement
Neye ihtiyacın var
  1. LG Stylo 2 Display Replacement, Battery: adım 1, 3 resimden 1. LG Stylo 2 Display Replacement, Battery: adım 1, 3 resimden 2. LG Stylo 2 Display Replacement, Battery: adım 1, 3 resimden 3.
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Display Replacement: adım 2, 3 resimden 1. LG Stylo 2 Display Replacement: adım 2, 3 resimden 2. LG Stylo 2 Display Replacement: adım 2, 3 resimden 3.
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Display Replacement, Rear Camera: adım 3, 3 resimden 1. LG Stylo 2 Display Replacement, Rear Camera: adım 3, 3 resimden 2. LG Stylo 2 Display Replacement, Rear Camera: adım 3, 3 resimden 3.
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Display Replacement: adım 4, 3 resimden 1. LG Stylo 2 Display Replacement: adım 4, 3 resimden 2. LG Stylo 2 Display Replacement: adım 4, 3 resimden 3.
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
    May I have your numbers so that we talk
    Isaac Ruteshengyereza - Yanıt
  5. LG Stylo 2 Display Replacement, Motherboard: adım 5, 3 resimden 1. LG Stylo 2 Display Replacement, Motherboard: adım 5, 3 resimden 2. LG Stylo 2 Display Replacement, Motherboard: adım 5, 3 resimden 3.
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
  6. LG Stylo 2 Display Replacement, Display: adım 6, 3 resimden 1. LG Stylo 2 Display Replacement, Display: adım 6, 3 resimden 2. LG Stylo 2 Display Replacement, Display: adım 6, 3 resimden 3.
    • Carefully remove the Vibrator.
    • Carefully remove the sensor.
    • Prepare to remove film.
    Don’t forget to remove the front facing camera.
    jhwv - Yanıt
  7. LG Stylo 2 Display Replacement: adım 7, 3 resimden 1. LG Stylo 2 Display Replacement: adım 7, 3 resimden 2. LG Stylo 2 Display Replacement: adım 7, 3 resimden 3.
    • Use the tweezers to peel the film off carefully.
    • Use the tweezers to remove the headphone jack gently.
    • Place all three devices in a safe, known, location.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Devon Barber
994 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G1, Cheng Spring 2018 USF Tampa, Team S11-G1, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G1
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Hello guys
I just replaced the screen for my LG Stylus 2 plus. I got the display off https://www.injuredgadgets.com/lg-stylus...
But after replacing the screen and turning it on only the back light is functioning. I tried reusing the old display and it worked just fine. Is there any suggestions to why this one is not working or is my new screen just a bust ?
Several Genie - Yanıt
I've got the same problem please help this phone has all my late sons pictures and my daughter's it's a LG Stylo 2
Cody Pinson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 5,876
