Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If the display on the phone is cracked or is unresponsive to touch in areas or the whole phone you may need to replace the display. This will require you to take everything out of the phone as the display itself cannot be removed solely without possible damage to other parts of the phone.
Neye ihtiyacın var
First you need to remove the back case of the phone.
Place the phone face down.
Using the plastic opening tool, insert into the initial gap shown.
Slowly guide the tool around the case until the case comes off with ease.
Remove the eleven 4mm Phillips #00 screws.
Place screws in safe location.
Use Plastic opener tool to remove inner case.
Gently remove inner case.
Gently flip the cables(shown in red boxes) using the opener tool.
Gently remove the motherboard itself.
Place motherboard on a soft surface to not damage it.
Carefully remove the Vibrator.
Carefully remove the sensor.
Prepare to remove film.
15 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Hello guys
I just replaced the screen for my LG Stylus 2 plus. I got the display off https://www.injuredgadgets.com/lg-stylus...
But after replacing the screen and turning it on only the back light is functioning. I tried reusing the old display and it worked just fine. Is there any suggestions to why this one is not working or is my new screen just a bust ?
I've got the same problem please help this phone has all my late sons pictures and my daughter's it's a LG Stylo 2
