Ana içeriğe geç
LG Stylo 2 Motherboard Replacement
Neye ihtiyacın var
  1. LG Stylo 2 Motherboard  Replacement, Battery: adım 1, 3 resimden 1. LG Stylo 2 Motherboard  Replacement, Battery: adım 1, 3 resimden 2. LG Stylo 2 Motherboard  Replacement, Battery: adım 1, 3 resimden 3.
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Motherboard  Replacement: adım 2, 3 resimden 1. LG Stylo 2 Motherboard  Replacement: adım 2, 3 resimden 2. LG Stylo 2 Motherboard  Replacement: adım 2, 3 resimden 3.
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Motherboard  Replacement, Rear Camera: adım 3, 3 resimden 1. LG Stylo 2 Motherboard  Replacement, Rear Camera: adım 3, 3 resimden 2. LG Stylo 2 Motherboard  Replacement, Rear Camera: adım 3, 3 resimden 3.
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Motherboard  Replacement: adım 4, 3 resimden 1. LG Stylo 2 Motherboard  Replacement: adım 4, 3 resimden 2. LG Stylo 2 Motherboard  Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  5. LG Stylo 2 Motherboard  Replacement, Motherboard: adım 5, 3 resimden 1. LG Stylo 2 Motherboard  Replacement, Motherboard: adım 5, 3 resimden 2. LG Stylo 2 Motherboard  Replacement, Motherboard: adım 5, 3 resimden 3.
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
Sonuç
Devon Barber
994 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G1, Cheng Spring 2018 USF Tampa, Team S11-G1, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G1
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Charging retain 2.1
Kashif Kashi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 2,233
