Ana içeriğe geç
LG Stylo 2 Plus Front Camera Replacement
Neye ihtiyacın var
  1. LG Stylo 2 Plus Front Camera Replacement, Rear Case: adım 1, 3 resimden 1. LG Stylo 2 Plus Front Camera Replacement, Rear Case: adım 1, 3 resimden 2. LG Stylo 2 Plus Front Camera Replacement, Rear Case: adım 1, 3 resimden 3.
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
    FixBot'a Sor
    Yorum Ekle
  2. LG Stylo 2 Plus Front Camera Replacement, Battery: adım 2, 3 resimden 1. LG Stylo 2 Plus Front Camera Replacement, Battery: adım 2, 3 resimden 2. LG Stylo 2 Plus Front Camera Replacement, Battery: adım 2, 3 resimden 3.
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. LG Stylo 2 Plus Front Camera Replacement, Mid-Frame: adım 3, 2 resimden 1. LG Stylo 2 Plus Front Camera Replacement, Mid-Frame: adım 3, 2 resimden 2.
    • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
    FixBot'a Sor
    Yorum Ekle
  4. LG Stylo 2 Plus Front Camera Replacement: adım 4, 2 resimden 1. LG Stylo 2 Plus Front Camera Replacement: adım 4, 2 resimden 2.
    • Insert the metal spudger in the dimple at the base of the cover.
    • Pry upward, removing the mid-frame from the phone.
    FixBot'a Sor
    Yorum Ekle
  5. LG Stylo 2 Plus Front Camera Replacement, Front Camera: adım 5, 3 resimden 1. LG Stylo 2 Plus Front Camera Replacement, Front Camera: adım 5, 3 resimden 2. LG Stylo 2 Plus Front Camera Replacement, Front Camera: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, carefully detach the ribbon cable connecting the camera to the motherboard.
    • Still using the tweezers, firmly pull up to remove the camera from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Joshua Sisson
73 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G3, Cardinal Spring 2019 UW Tacoma, Team S1-G3, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G3
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 546
