Ana içeriğe geç
LG Stylo 2 Plus Speaker Replacement
Neye ihtiyacın var
  1. LG Stylo 2 Plus Speaker Replacement, Rear Case: adım 1, 3 resimden 1. LG Stylo 2 Plus Speaker Replacement, Rear Case: adım 1, 3 resimden 2. LG Stylo 2 Plus Speaker Replacement, Rear Case: adım 1, 3 resimden 3.
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Speaker Replacement, Battery: adım 2, 3 resimden 1. LG Stylo 2 Plus Speaker Replacement, Battery: adım 2, 3 resimden 2. LG Stylo 2 Plus Speaker Replacement, Battery: adım 2, 3 resimden 3.
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
  3. LG Stylo 2 Plus Speaker Replacement, Speaker: adım 3, 2 resimden 1. LG Stylo 2 Plus Speaker Replacement, Speaker: adım 3, 2 resimden 2.
    • Remove the cover from the phone in order to access the speaker.
    • Using the JIS #000 screwdriver, remove the four 4mm screws around the base of the mid-frame.
  4. LG Stylo 2 Plus Speaker Replacement: adım 4, 2 resimden 1. LG Stylo 2 Plus Speaker Replacement: adım 4, 2 resimden 2.
    • Insert the metal spudger in the dimple at the base of the mid-frame.
    • Pry upward, removing bottom section of the mid-frame from the phone.
  5. LG Stylo 2 Plus Speaker Replacement: adım 5, 3 resimden 1. LG Stylo 2 Plus Speaker Replacement: adım 5, 3 resimden 2. LG Stylo 2 Plus Speaker Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip the bottom piece of the mid-frame over to show the speaker in the bottom right corner.
    • Using the tweezers, peel back the rubber resting on top of the speaker.
    • Still using the tweezers, grasp the speaker unit and remove it from the mid-frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Noah Kehm
241 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G3, Cardinal Spring 2019 UW Tacoma, Team S1-G3, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 477
