Giriş
If your phone's selfie camera is failing to take pictures, it may be time to replace the front camera. This guide will take you step by step on how to replace the camera of your LG Stylo 3 Plus in about 5 minutes.
Neye ihtiyacın var
Place the phone face down.
Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
Place the back cover off to the side.
Insert the opening tool into the small gap below the battery.
Carefully pop the battery out to prevent damage.
Remove the twelve 4mm screws using the Phillips #000 screwdriver.
Use the plastic opening tool to remove the inner case.
Carefully remove the inner case.
Carefully flip open the flex cable box with the plastic opening tool.
Using precision tweezers, carefully lift the front camera off the device.
Bir başkası bu kılavuzu tamamladı.
