Ana içeriğe geç
LG Stylo 3 Plus Front Camera Replacement
Neye ihtiyacın var
  1. LG Stylo 3 Plus Front Camera Replacement, Back Cover: adım 1, 3 resimden 1. LG Stylo 3 Plus Front Camera Replacement, Back Cover: adım 1, 3 resimden 2. LG Stylo 3 Plus Front Camera Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
    FixBot'a Sor
    Yorum Ekle
  2. LG Stylo 3 Plus Front Camera Replacement, Battery: adım 2, 3 resimden 1. LG Stylo 3 Plus Front Camera Replacement, Battery: adım 2, 3 resimden 2. LG Stylo 3 Plus Front Camera Replacement, Battery: adım 2, 3 resimden 3.
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
    FixBot'a Sor
    Yorum Ekle
  3. LG Stylo 3 Plus Front Camera Replacement, Rear Camera: adım 3, 3 resimden 1. LG Stylo 3 Plus Front Camera Replacement, Rear Camera: adım 3, 3 resimden 2. LG Stylo 3 Plus Front Camera Replacement, Rear Camera: adım 3, 3 resimden 3.
    • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
    • Use the plastic opening tool to remove the inner case.
    • Carefully remove the inner case.
    FixBot'a Sor
    Yorum Ekle
  4. LG Stylo 3 Plus Front Camera Replacement: adım 4, 2 resimden 1. LG Stylo 3 Plus Front Camera Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use your fingernail or the plastic opening tool to flip the flex cable.
    • Use the precision tweezers to carefully grasp and pull out the camera.
    FixBot'a Sor
    Yorum Ekle
  5. LG Stylo 3 Plus Front Camera Replacement, Front Camera: adım 5, 2 resimden 1. LG Stylo 3 Plus Front Camera Replacement, Front Camera: adım 5, 2 resimden 2.
    • Carefully flip open the flex cable box with the plastic opening tool.
    • Using precision tweezers, carefully lift the front camera off the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patricia Pires Dias
945 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G6, Peak Fall 2018 UMass Dartmouth, Team S2-G6, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G6
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,188
