Ana içeriğe geç
LG Sunrise Midframe Replacement
Neye ihtiyacın var
  1. LG Sunrise Midframe Replacement, Back cover: adım 1, 1 resimden 1.
    • Flip the phone over so the back side is facing you.
  2. LG Sunrise Midframe Replacement: adım 2, 1 resimden 1.
    • Use a prying tool or a flat head screwdriver to pry the back cover from the device.
  3. LG Sunrise Midframe Replacement: adım 3, 1 resimden 1.
    • Set back panel aside for later use or to replace.
  4. LG Sunrise Midframe Replacement, Battery: adım 4, 2 resimden 1. LG Sunrise Midframe Replacement, Battery: adım 4, 2 resimden 2.
    • Use your finger to pull out battery from the bottom of the device.
  5. Dikkatli ol: adımlar 5-6 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    LG Sunrise Midframe Replacement, Lower Back Plastic Piece: adım 5, 3 resimden 1. LG Sunrise Midframe Replacement, Lower Back Plastic Piece: adım 5, 3 resimden 2. LG Sunrise Midframe Replacement, Lower Back Plastic Piece: adım 5, 3 resimden 3.
    • You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
  6. LG Sunrise Midframe Replacement: adım 6, 1 resimden 1.
    • Once both of the screws are out you can easily pop off the bottom piece.
  7. LG Sunrise Midframe Replacement, Midframe: adım 7, 2 resimden 1. LG Sunrise Midframe Replacement, Midframe: adım 7, 2 resimden 2.
    • Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
  8. LG Sunrise Midframe Replacement: adım 8, 2 resimden 1. LG Sunrise Midframe Replacement: adım 8, 2 resimden 2.
    • Once you have pried off the back piece, the mother board should be exposed. Set this piece aside for replacement or reassembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Paxton Fox
257 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 261
