Ana içeriğe geç
LG TP 1100 Microphone Replacement
Neye ihtiyacın var
  1. LG TP 1100 Microphone Replacement, Microphone: adım 1, 1 resimden 1.
    • Hold antenna between your fingers and unscrew in a counterclockwise direction.
  2. LG TP 1100 Microphone Replacement: adım 2, 1 resimden 1.
    • You will remove antenna by pulling it in an upward motion away from the socket.
  3. LG TP 1100 Microphone Replacement: adım 3, 1 resimden 1.
    • Turn phone so that the back is facing you.
  4. LG TP 1100 Microphone Replacement: adım 4, 1 resimden 1.
    • Use your thumb to pull the tab in an upward motion to release the battery.
  5. LG TP 1100 Microphone Replacement: adım 5, 1 resimden 1.
    • Hold phone securely in one hand and pull the battery away from the phone with your other hand.
  6. LG TP 1100 Microphone Replacement: adım 6, 1 resimden 1.
    • Use your screwdriver to unscrew the four screws from the back plate.
  7. LG TP 1100 Microphone Replacement: adım 7, 1 resimden 1.
    • Turn phone to the side as indicated in the picture.
  8. LG TP 1100 Microphone Replacement: adım 8, 1 resimden 1.
    • Remove the back cover that you just unscrewed and set aside.
  9. LG TP 1100 Microphone Replacement: adım 9, 1 resimden 1.
    • Open the remaining parts like a book but do not separate the two pieces.
    • Do not tear the tape connecting the two pieces.
  10. LG TP 1100 Microphone Replacement: adım 10, 2 resimden 1. LG TP 1100 Microphone Replacement: adım 10, 2 resimden 2.
    • Rotate the phone so that the circuit board is in the palm of your hand and the part connected with tape hangs behind.
    • Use your opening tool to pry the circuit board from the front cover. Do not let the number pad to fall out.
  11. LG TP 1100 Microphone Replacement: adım 11, 1 resimden 1.
    • To remove the microphone, insert your opening tool under microphone and push upward to pry microphone away from the front cover.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Johnny Inlow
19 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-91, Amido Spring 2010 Cal Poly, Team 27-91, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G91
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 1,327
