Ana içeriğe geç
LG Thrill 4G SIM/Micro SD Card Replacement
Neye ihtiyacın var
  1. LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: adım 1, 2 resimden 1. LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: adım 1, 2 resimden 2.
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: adım 2, 2 resimden 1. LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: adım 2, 2 resimden 2.
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G SIM/Micro SD Card Replacement, Screw Removal: adım 3, 1 resimden 1.
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: adım 4, 2 resimden 1. LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: adım 4, 2 resimden 2.
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G SIM/Micro SD Card Replacement, Buttons: adım 5, 1 resimden 1.
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G SIM/Micro SD Card Replacement: adım 6, 3 resimden 1. LG Thrill 4G SIM/Micro SD Card Replacement: adım 6, 3 resimden 2. LG Thrill 4G SIM/Micro SD Card Replacement: adım 6, 3 resimden 3.
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G SIM/Micro SD Card Replacement: adım 7, 1 resimden 1.
    • Remove the six Phillips #00 screws within the mid-cover bezel.
  8. LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: adım 8, 3 resimden 1. LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: adım 8, 3 resimden 2. LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: adım 8, 3 resimden 3.
    • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
  9. LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: adım 9, 3 resimden 1. LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: adım 9, 3 resimden 2. LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: adım 9, 3 resimden 3.
    • Carefully pry the board up to detach it from its place in the phone.
    • Make sure to pry off the small tab connected to the camera unit as well.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Khbero Baker
128 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Blackwell Winter 2015 USF Tampa, Team 1-6, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S1G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 595
