Ana içeriğe geç
LG Tone Infinim HBS-910 Battery Replacement
Neye ihtiyacın var
  1. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: adım 1, 3 resimden 1. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: adım 1, 3 resimden 2. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: adım 1, 3 resimden 3.
    • Battery is on right side of headset.
    • First remove rubber cover on the right side of the headset to uncover the hidden screw.
    • Remove screw using Philips PH00 screwdriver.
  2. LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: adım 2, 2 resimden 1. LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: adım 2, 2 resimden 2.
    • Use a guitar pick or any opening tool to pry open the right side.
  3. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: adım 3, 3 resimden 1. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: adım 3, 3 resimden 2. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: adım 3, 3 resimden 3.
    • Once you have opened the right side up until the speaker end, there will be a hidden screw that needs to be unscrewed before the right side can be completely disassembled.
    • Pry open the speaker back housing with a guitar pick or any opening tool as shown in the picture.
    • Once the speaker back housing is lifted, you will see the screw.
    • Remove the screw and the whole right side will be disassembled.
  4. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: adım 4, 3 resimden 1. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: adım 4, 3 resimden 2. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: adım 4, 3 resimden 3.
    • Use a non-metal tool to lift the battery out of place so it will be easy to desolder.
    • Remember the red wire is positive(+) and the black wire is negative(-).
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Faizan Naveed
3.294 İtibar
8 adet Kılavuz yazıldı
Ekip
Mobile Device Repair Factory Mobile Device Repair Factory üyesi
Business
1 Üye
16 adet Kılavuz yazıldı
2 Yorum
Battery model and amps
honda kung - Yanıt
Hello budy!
Tanks for the guide, i was going crazy looking for that hidden screw!
You might be able to help me. Would you know what i must look for a malfunctioning earbud? My right one suddenly died and im hoping the cord isn't broken and its just some loose weld.
Rafael Zerbini - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 40
Her zaman: 11,377
