Ana içeriğe geç
LG Tone Pro HBS-760 Speaker Replacement
Neye ihtiyacın var
  1. LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: adım 1, 3 resimden 1. LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: adım 1, 3 resimden 2. LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: adım 1, 3 resimden 3.
    • Locate the right and left side speaker where the hidden screw is located and remove the rubber piece covering the screw.
  2. LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: adım 2, 2 resimden 1. LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: adım 2, 2 resimden 2.
    • Using a Philips #00 screwdriver, remove the hidden screws from both sides.
  3. LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: adım 3, 3 resimden 1. LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: adım 3, 3 resimden 2. LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: adım 3, 3 resimden 3.
    • Use a guitar pick or any opening tool to pry open the housing for the side you want to replace the speaker.
  4. LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: adım 4, 3 resimden 1. LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: adım 4, 3 resimden 2. LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: adım 4, 3 resimden 3.
    • Right side can be de-soldered right away but the left side speaker solder connection to the board is covered by rubber material which needs to be removed first before it can be de-soldered.
  5. LG Tone Pro HBS-760 Speaker  Replacement, Replace Speakers: adım 5, 1 resimden 1.
    • Once the speakers have been de-soldered, replace with new ones.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Faizan Naveed
3.294 İtibar
8 adet Kılavuz yazıldı
Ekip
Mobile Device Repair Factory Mobile Device Repair Factory üyesi
Business
1 Üye
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 1,519
