Ana içeriğe geç
LG Treasure Auxiliary Port Replacement
Neye ihtiyacın var
  1. LG Treasure Auxiliary Port Replacement, Battery: adım 1, 2 resimden 1. LG Treasure Auxiliary Port Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. LG Treasure Auxiliary Port Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. LG Treasure Auxiliary Port Replacement, Auxiliary Port: adım 3, 2 resimden 1. LG Treasure Auxiliary Port Replacement, Auxiliary Port: adım 3, 2 resimden 2.
    • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. LG Treasure Auxiliary Port Replacement: adım 4, 3 resimden 1. LG Treasure Auxiliary Port Replacement: adım 4, 3 resimden 2. LG Treasure Auxiliary Port Replacement: adım 4, 3 resimden 3.
    • Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
david amirahmadi
561 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G5, Ogden Spring 2018 UW Stout, Team S8-G5, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 238
