Ana içeriğe geç
LG Treasure Rear Camera Replacement
Neye ihtiyacın var
  1. LG Treasure Rear Camera Replacement, Battery: adım 1, 2 resimden 1. LG Treasure Rear Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
    FixBot'a Sor
    Yorum Ekle
  2. LG Treasure Rear Camera Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
    FixBot'a Sor
    Yorum Ekle
  3. LG Treasure Rear Camera Replacement, Rear Camera: adım 3, 2 resimden 1. LG Treasure Rear Camera Replacement, Rear Camera: adım 3, 2 resimden 2.
    • Remove all 9 of the 3 mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
    FixBot'a Sor
    Yorum Ekle
  4. LG Treasure Rear Camera Replacement: adım 4, 2 resimden 1. LG Treasure Rear Camera Replacement: adım 4, 2 resimden 2.
    • Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
david amirahmadi
594 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G5, Ogden Spring 2018 UW Stout, Team S8-G5, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G5
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 492
