Ana içeriğe geç
LG Treasure Rear Camera Replacement
Neye ihtiyacın var
  1. LG Treasure Rear Camera Replacement, Battery: adım 1, 2 resimden 1. LG Treasure Rear Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. LG Treasure Rear Camera Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. LG Treasure Rear Camera Replacement, Rear Camera: adım 3, 2 resimden 1. LG Treasure Rear Camera Replacement, Rear Camera: adım 3, 2 resimden 2.
    • Remove all 9 of the 3 mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. LG Treasure Rear Camera Replacement: adım 4, 2 resimden 1. LG Treasure Rear Camera Replacement: adım 4, 2 resimden 2.
    • Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
david amirahmadi
576 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G5, Ogden Spring 2018 UW Stout, Team S8-G5, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 213
