Ana içeriğe geç
LG Tribute 5 Motherboard Replacement
Neye ihtiyacın var
  1. LG Tribute 5 Motherboard Replacement, Battery: adım 1, 2 resimden 1. LG Tribute 5 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. LG Tribute 5 Motherboard Replacement: adım 2, 3 resimden 1. LG Tribute 5 Motherboard Replacement: adım 2, 3 resimden 2. LG Tribute 5 Motherboard Replacement: adım 2, 3 resimden 3.
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. LG Tribute 5 Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. LG Tribute 5 Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. LG Tribute 5 Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute 5 Motherboard Replacement: adım 4, 3 resimden 1. LG Tribute 5 Motherboard Replacement: adım 4, 3 resimden 2. LG Tribute 5 Motherboard Replacement: adım 4, 3 resimden 3.
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. LG Tribute 5 Motherboard Replacement: adım 5, 2 resimden 1. LG Tribute 5 Motherboard Replacement: adım 5, 2 resimden 2.
    • Gently remove the mid-frame using an iFixit opening tool as shown.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. LG Tribute 5 Motherboard Replacement: adım 6, 2 resimden 1. LG Tribute 5 Motherboard Replacement: adım 6, 2 resimden 2.
    • Using an iFixit opening tool, gently disconnect the rear camera from the top center of the motherboard.
    • Remove the front facing camera from the top right corner of the motherboard.
  7. LG Tribute 5 Motherboard Replacement: adım 7, 1 resimden 1.
    • Gently pull the speaker out from its compartment with the iFixit opening tool.
  8. LG Tribute 5 Motherboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the flex cable from the motherboard with the iFixit opening tool.
  9. LG Tribute 5 Motherboard Replacement: adım 9, 1 resimden 1.
    • Gently pull up and remove the motherboard using the iFixit opening tool.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Renee Dawn Nelson
454 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G6, Cardinal Spring 2019 UW Tacoma, Team S1-G6, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 388
