Ana içeriğe geç
LG Tribute Front Facing Camera Replacement
Neye ihtiyacın var
  1. LG Tribute Front Facing Camera  Replacement, Battery: adım 1, 2 resimden 1. LG Tribute Front Facing Camera  Replacement, Battery: adım 1, 2 resimden 2.
    • Use the plastic opening tool to pry off the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. LG Tribute Front Facing Camera  Replacement: adım 2, 1 resimden 1.
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
    FixBot'a Sor
    Yorum Ekle
  3. LG Tribute Front Facing Camera  Replacement, Mid-panel: adım 3, 2 resimden 1. LG Tribute Front Facing Camera  Replacement, Mid-panel: adım 3, 2 resimden 2.
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    FixBot'a Sor
    Yorum Ekle
  4. LG Tribute Front Facing Camera  Replacement: adım 4, 2 resimden 1. LG Tribute Front Facing Camera  Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
    FixBot'a Sor
    Yorum Ekle
  5. LG Tribute Front Facing Camera  Replacement, Front Facing Camera: adım 5, 2 resimden 1. LG Tribute Front Facing Camera  Replacement, Front Facing Camera: adım 5, 2 resimden 2.
    • Use the plastic opening tool to carefully pry the front-facing camera from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,315
