Ana içeriğe geç
Giriş
In this guide we will teach you how to properly remove and replace the LG Tribute HD's volume and power buttons
Parçalar
Hiçbir parça belirtilmedi.
  1. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. Pull the battery out of the phone. Remove the SD Card by sliding the card out as shown.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  4. Remove the twelve 2mm JIS #00 screws from the mid-frame. Remove the twelve 2mm JIS #00 screws from the mid-frame.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  5. Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame.
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
  6. Using your fingers, remove the mid-frame. Using your fingers, remove the mid-frame.
    • Using your fingers, remove the mid-frame.
  7. Use a plastic opening tool to remove the buttons by pushing them in until they pop through. Use a plastic opening tool to remove the buttons by pushing them in until they pop through.
    • Use a plastic opening tool to remove the buttons by pushing them in until they pop through.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dhruv Patel
268 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team S1-G3, Nance Spring 2018 USF Tampa, Team S1-G3, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G3
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Thanks man. It worked!
Elijah Montgomery - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 15
Her zaman: 324
