Ana içeriğe geç
LG Tribute HD Display Replacement
Neye ihtiyacın var
  1. LG Tribute HD Display Replacement, Battery and SD Card: adım 1, 2 resimden 1. LG Tribute HD Display Replacement, Battery and SD Card: adım 1, 2 resimden 2.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    FixBot'a Sor
    Yorum Ekle
  2. LG Tribute HD Display Replacement: adım 2, 2 resimden 1. LG Tribute HD Display Replacement: adım 2, 2 resimden 2.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
    FixBot'a Sor
    Yorum Ekle
  3. LG Tribute HD Display Replacement, Flex Cable: adım 3, 2 resimden 1. LG Tribute HD Display Replacement, Flex Cable: adım 3, 2 resimden 2.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
    FixBot'a Sor
    Yorum Ekle
  4. LG Tribute HD Display Replacement: adım 4, 3 resimden 1. LG Tribute HD Display Replacement: adım 4, 3 resimden 2. LG Tribute HD Display Replacement: adım 4, 3 resimden 3.
    • Using a plastic opening tool, remove the antenna extender from the bottom.
    FixBot'a Sor
    Yorum Ekle
  5. LG Tribute HD Display Replacement: adım 5, 2 resimden 1. LG Tribute HD Display Replacement: adım 5, 2 resimden 2.
    • Using your fingers, remove the mid-frame.
    FixBot'a Sor
    Yorum Ekle
  6. LG Tribute HD Display Replacement: adım 6, 3 resimden 1. LG Tribute HD Display Replacement: adım 6, 3 resimden 2. LG Tribute HD Display Replacement: adım 6, 3 resimden 3.
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard.
    • Remove the cameras from the phone.
    FixBot'a Sor
    Yorum Ekle
  7. LG Tribute HD Display Replacement: adım 7, 3 resimden 1. LG Tribute HD Display Replacement: adım 7, 3 resimden 2. LG Tribute HD Display Replacement: adım 7, 3 resimden 3.
    • Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
    FixBot'a Sor
    Yorum Ekle
  8. LG Tribute HD Display Replacement: adım 8, 1 resimden 1.
    • Disconnect the LCD from the motherboard with a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  9. LG Tribute HD Display Replacement: adım 9, 2 resimden 1. LG Tribute HD Display Replacement: adım 9, 2 resimden 2.
    • Use a plastic opening tool to pry up the motherboard form the display housing.
    • Remove the motherboard from the phone.
    FixBot'a Sor
    Yorum Ekle
  10. LG Tribute HD Display Replacement: adım 10, 2 resimden 1. LG Tribute HD Display Replacement: adım 10, 2 resimden 2.
    • Use your fingers to remove the flex cables from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Aalia Mohammed
454 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Nance Spring 2018 USF Tampa, Team S1-G3, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G3
4 Üyeler
34 adet Kılavuz yazıldı
5Kılavuz Yorumları
Just a note that the flex cables are stuck pretty well to the case. I didn’t rip them but I used a little heat from a hair dryer to soften the glue a bit.
christophergosnell - Yanıt Paylaş
I somewhat agree with christophergosnell on this one but I did manage to lift up the ribbon cables using both my fingernails and a small, then, flat head screwdriver at just the right points. there is also a ribbon cable near the bottom of the phone that I had to transplant that is shown but you don’t include a picture of you even attempting to remove it. I didn’t pay attention what it connected to but I just made sure it went in the same spot on the new screen assembly. Other then that a pretty decent guide.
Robert Surles - Yanıt Paylaş
Many thanks to the previous comments! The guide is very helpful but could use more detail. I missed the ribbon at the bottom and couldn’t figure out why my speaker wasn’t working. I spent two hours taking the speaker in and out and re-bending the contacts to improve the connection until I checked the comments here and noticed the other ribbon. It was hard to get off so I used a heat gun on low just long enough to soften the glue and then I was finally able to get it off. This solved the speaker problem and all is working well.
James Stephens - Yanıt Paylaş
I also used a blow dryer for heat , and small jewellers screwdriver to transfer the ribbons. I also used a magnifying glass
dartswinger70 - Yanıt Paylaş
I have reassembled my phone, and it works! Success!. Yes, the disassembly was going smooth, until the ribbon transfer. That's when I stopped, read the comments about using a hair dryer for heat etc. It also helps to have the tools shown in the pic, or very small jewellers screwdriver set like in eyeglasses repair kits.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 3,451
