Ana içeriğe geç
LG Tribute HD Motherboard Replacement
Neye ihtiyacın var
  1. LG Tribute HD Motherboard Replacement, Battery and SD Card: adım 1, 2 resimden 1. LG Tribute HD Motherboard Replacement, Battery and SD Card: adım 1, 2 resimden 2.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. LG Tribute HD Motherboard Replacement: adım 2, 2 resimden 1. LG Tribute HD Motherboard Replacement: adım 2, 2 resimden 2.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. LG Tribute HD Motherboard Replacement, Motherboard: adım 3, 2 resimden 1. LG Tribute HD Motherboard Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute HD Motherboard Replacement: adım 4, 3 resimden 1. LG Tribute HD Motherboard Replacement: adım 4, 3 resimden 2. LG Tribute HD Motherboard Replacement: adım 4, 3 resimden 3.
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
  5. LG Tribute HD Motherboard Replacement: adım 5, 2 resimden 1. LG Tribute HD Motherboard Replacement: adım 5, 2 resimden 2.
    • Using your fingers, remove the mid-frame.
  6. LG Tribute HD Motherboard Replacement: adım 6, 3 resimden 1. LG Tribute HD Motherboard Replacement: adım 6, 3 resimden 2. LG Tribute HD Motherboard Replacement: adım 6, 3 resimden 3.
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard and pull out to remove.
  7. LG Tribute HD Motherboard Replacement: adım 7, 3 resimden 1. LG Tribute HD Motherboard Replacement: adım 7, 3 resimden 2. LG Tribute HD Motherboard Replacement: adım 7, 3 resimden 3.
    • Using a plastic opening tool, pry up the front facing speaker and remove from the phone.
  8. LG Tribute HD Motherboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the display from the motherboard.
  9. LG Tribute HD Motherboard Replacement: adım 9, 2 resimden 1. LG Tribute HD Motherboard Replacement: adım 9, 2 resimden 2.
    • Use a plastic opening tool to pry up the motherboard and pull out to remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Aalia Mohammed
448 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Nance Spring 2018 USF Tampa, Team S1-G3, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G3
4 Üyeler
20 adet Kılavuz yazıldı
Bir Yorum
svp ou peut-on trouver cette carte mère
Mourasilva Silva - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 999
