Ana içeriğe geç
LG Tribute HD Rear Camera Replacement
Neye ihtiyacın var
  1. LG Tribute HD Rear Camera  Replacement, Battery and SD Card: adım 1, 2 resimden 1. LG Tribute HD Rear Camera  Replacement, Battery and SD Card: adım 1, 2 resimden 2.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    FixBot'a Sor
    Yorum Ekle
  2. LG Tribute HD Rear Camera  Replacement: adım 2, 2 resimden 1. LG Tribute HD Rear Camera  Replacement: adım 2, 2 resimden 2.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
    FixBot'a Sor
    Yorum Ekle
  3. LG Tribute HD Rear Camera  Replacement, Rear Camera: adım 3, 2 resimden 1. LG Tribute HD Rear Camera  Replacement, Rear Camera: adım 3, 2 resimden 2.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
    FixBot'a Sor
    Yorum Ekle
  4. LG Tribute HD Rear Camera  Replacement: adım 4, 3 resimden 1. LG Tribute HD Rear Camera  Replacement: adım 4, 3 resimden 2. LG Tribute HD Rear Camera  Replacement: adım 4, 3 resimden 3.
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
    FixBot'a Sor
    Yorum Ekle
  5. LG Tribute HD Rear Camera  Replacement: adım 5, 2 resimden 1. LG Tribute HD Rear Camera  Replacement: adım 5, 2 resimden 2.
    • Using your fingers, remove the mid-frame.
    FixBot'a Sor
    Yorum Ekle
  6. LG Tribute HD Rear Camera  Replacement: adım 6, 2 resimden 1. LG Tribute HD Rear Camera  Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool to disconnect the rear camera and pull from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Aalia Mohammed
454 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Nance Spring 2018 USF Tampa, Team S1-G3, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G3
4 Üyeler
34 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 639
