Ana içeriğe geç
LG Tribute Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. LG Tribute Rear-Facing Camera Replacement, Battery: adım 1, 2 resimden 1. LG Tribute Rear-Facing Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Use the plastic opening tool to pry off the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. LG Tribute Rear-Facing Camera Replacement: adım 2, 1 resimden 1.
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
    FixBot'a Sor
    Yorum Ekle
  3. LG Tribute Rear-Facing Camera Replacement, Mid-panel: adım 3, 2 resimden 1. LG Tribute Rear-Facing Camera Replacement, Mid-panel: adım 3, 2 resimden 2.
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    FixBot'a Sor
    Yorum Ekle
  4. LG Tribute Rear-Facing Camera Replacement: adım 4, 2 resimden 1. LG Tribute Rear-Facing Camera Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
    FixBot'a Sor
    Yorum Ekle
  5. LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: adım 5, 2 resimden 1. LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: adım 5, 2 resimden 2.
    • Disconnect the rear facing camera from the motherboard using a plastic opening tool.
    • Lift the rear facing camera out of its housing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 902
