Ana içeriğe geç
LG Tribute Touchscreen Replacement
Neye ihtiyacın var
  1. LG Tribute Touchscreen Replacement, Battery: adım 1, 2 resimden 1. LG Tribute Touchscreen Replacement, Battery: adım 1, 2 resimden 2.
    • Use the plastic opening tool to pry off the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. LG Tribute Touchscreen Replacement: adım 2, 1 resimden 1.
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
    FixBot'a Sor
    Yorum Ekle
  3. LG Tribute Touchscreen Replacement, Mid-panel: adım 3, 2 resimden 1. LG Tribute Touchscreen Replacement, Mid-panel: adım 3, 2 resimden 2.
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    FixBot'a Sor
    Yorum Ekle
  4. LG Tribute Touchscreen Replacement: adım 4, 2 resimden 1. LG Tribute Touchscreen Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
    FixBot'a Sor
    Yorum Ekle
  5. LG Tribute Touchscreen Replacement, Motherboard: adım 5, 1 resimden 1.
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
    FixBot'a Sor
    Yorum Ekle
  6. LG Tribute Touchscreen Replacement, Touchscreen: adım 6, 3 resimden 1. LG Tribute Touchscreen Replacement, Touchscreen: adım 6, 3 resimden 2. LG Tribute Touchscreen Replacement, Touchscreen: adım 6, 3 resimden 3.
    • Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
    • When the frame is completely free, remove all of the glue.
    • When removing the glue, be sure the speaker grill and LED light spacer do not dislodge.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
thank you for all ypu work at web site
salah dholman - Yanıt Paylaş
Can you peel away lens without taking apart ?
mikeknapik1 - Yanıt Paylaş
Must I remove the motherboard to replace the front cover with the glass?
Deb Schell - Yanıt Paylaş
I messed up the speaker is there a way to replace or fix it
bigestbabybratt - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 43
Her zaman: 16,561
