Ana içeriğe geç
LG UD501KOJ5 Dehumidifier Sensor Replacement
Neye ihtiyacın var
  1. LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: adım 1, 2 resimden 1. LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: adım 1, 2 resimden 2.
    • Unplug the dehumidifier then put on work gloves to protect your hands.
    • Remove the water collection bucket and set it aside.
    • Remove the air filter from the bottom of the front grille.
  2. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 2, 2 resimden 1. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 2, 2 resimden 2.
    • Using your Phillips #0 screwdriver, remove the two screws which are attached at the bottom of the front grille.
    • Lift the front grille up and off the front of the frame, carefully set it in front of the dehumidifier.
    • The control board wire harness is still attached to the back of the front grille.
  3. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 3, 3 resimden 1. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 3, 3 resimden 2. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 3, 3 resimden 3.
    • Remove the screws that secure the back panel to the dehumidifier.
    • Carefully remove the back panel from the dehumidifier.
    • Remove the screws at the side.
  4. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 4, 3 resimden 1. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 4, 3 resimden 2. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 4, 3 resimden 3.
    • Remove the screws located at both sides of the back panel.
    • Remove the screws on the top left and top right which are connected to the control box.
    • Carefully remove the outer case.
  5. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 5, 3 resimden 1. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 5, 3 resimden 2. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 5, 3 resimden 3.
    • Disconnect the sensor wire harness from the electronic control board.
    • Disconnect the wire harness from the collection bucket float switch.
    • Pull the evaporator thermistor out of the copper sleeve on the side of the evaporator coil.
  6. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 6, 2 resimden 1. LG UD501KOJ5 Dehumidifier Sensor Replacement: adım 6, 2 resimden 2.
    • Remove the humidity sensor from the evaporator fins.
    • Pull the sensor assembly out of the dehumidifier.
    • Remove any dust build-up with a dry cloth.
    • Push the new humidity sensor in place on the front of the evaporator fins.
Sonuç
Gabrielle Campbell
133 İtibar
1 Kılavuz yazıldı
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 55
Her zaman: 1,902
