Ana içeriğe geç
Giriş
This guide will teach you how to remove the battery from the phone. This will require you to use the plastic opening tool to loosen the back cover of the phone, remove the back cover with your hands, and then remove the battery with the plastic opening tool.
Parçalar
Hiçbir parça belirtilmedi.
  1. Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
    • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
  2. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  3. Use your hand to pull the plastic cover completely off of the phone.
    • Use your hand to pull the plastic cover completely off of the phone.
  4. Insert the plastic opening tool into the wedge near the bottom of the battery.
    • Insert the plastic opening tool into the wedge near the bottom of the battery.
    • Lift the battery out.
Sonuç
Jiffy Bishop
97 İtibar
1 Kılavuz yazıldı
Takım
IUPUI, Team S5-G2, Baechle Spring 2018 IUPUI, Team S5-G2, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S5G2
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 6
Her zaman: 209
