Ana içeriğe geç
LG V10 Battery Replacement
Neye ihtiyacın var
  1. LG V10 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
    FixBot'a Sor
    Yorum Ekle
  2. LG V10 Battery Replacement: adım 2, 2 resimden 1. LG V10 Battery Replacement: adım 2, 2 resimden 2.
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
    FixBot'a Sor
    Yorum Ekle
Sonuç
After replacing the old battery with a new one, reattach the back cover and press down on all sides to make sure it's properly reattached.
3 farklı kişi bu kılavuzu tamamladı.
Nikolai Lesh
344 İtibar
1 Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
333 Üyeler
1.694 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 62
Her zaman: 3,633
