Giriş
Before replacing the battery, turn off the LG V10. If your LG V10 is being charged for a couple hours but quickly drains even when it’s not being used, for example the battery percentage goes from 100% to 95% within ten minutes of being unplugged, then the battery’s life has been depleted and may need to be replaced.
Neye ihtiyacın var
Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
After replacing the old battery with a new one, reattach the back cover and press down on all sides to make sure it's properly reattached.
3 farklı kişi bu kılavuzu tamamladı.
